1995 S-10 Blazer 4x4
STEVEADAMS
I have a 95 4x4 blazer with a auto tranny.When i try to engage the 4wd nothing happens. I can take the cable loose under the battery tray and engage it that way. What do i need to replace to fix this problem?
Nov 8, 2007 at 3:17 PM
BMRFIXIT
  • 19,053 POSTS
[quote:016a5217bc="Steveadams"]I have a 95 4x4 blazer with a auto tranny.When i try to engage the 4wd nothing happens. I can take the cable loose under the battery tray and engage it that way. What do i need to replace to fix this problem?[/quote:016a5217bc]
Check vacuum lines and switch on transfer case
Nov 8, 2007 at 10:19 PM
