1995 Chevy S-10 water pump?
ELWOOD74
Engine Cooling problem
1995 Chevy S-10 4 cyl Automatic
how do you remove a water pump from this vehicle
Aug 14, 2010 at 8:52 AM
  • 75,988 POSTS
Disconnect battery ground cable, then drain coolant from radiator.
Remove drive belts and upper fan shroud
Remove fan and fan clutch assembly.
Remove coolant pump pulley, then radiator outlet hose clamp and hose.
Remove bolts and studs, then coolant pump.
Reverse procedure to install.
Aug 14, 2010 at 9:48 AM
