Disconnect battery ground cable, then drain coolant from radiator.
Remove drive belts and upper fan shroud
Remove fan and fan clutch assembly.
Remove coolant pump pulley, then radiator outlet hose clamp and hose.
Remove bolts and studs, then coolant pump.
Reverse procedure to install.
SPONSORED LINKS
Saturday, August 14th, 2010 AT 4:48 PM
