1995 Chevy S-10 throttle body injection delivers too much f
1995 CHEVROLET S-10
JYNXX15
  • 6 POSTS
Engine Mechanical problem
1995 Chevy S-10 6 cyl Four Wheel Drive Automatic
Truck runs good with only one injector attached, attached both & it won't stay cranked. Have replaced ECM, injector control valve(?), computer, etc. trying to get it to run, now it runs pitiful. Done a tune up, had someone else double check work, corrected one problem (got it to crank at least). Anyone got any ideas of how to fix this? Help!
May 9, 2008 at 10:42 PM
Check the fuel pressure and get back to me-you sure your injectors are working properly-you can tell by observing the spary pattern while engine is running
May 9, 2008 at 11:06 PM
JYNXX15
  • 6 POSTS
Spray pattern is fan to cone shaped. Sorry it took so long to get back to you.
May 15, 2008 at 9:34 PM
JYNXX15
  • 6 POSTS
scan tool gives no codes. I will try again tomorrow.
May 15, 2008 at 10:30 PM
JYNXX15
  • 6 POSTS
jakestruck- No luck there. I'm still working with a new scanner.
rasmataz- Fan shaped pattern. New fuel pressure regulator on it- no change in pattern.
May 22, 2008 at 9:36 PM
