1995 Chevy S-10 thermostat
DALTONSAR1
  • 1995 CHEVROLET S-10
  • 4 CYL
  • 156,000 MILES
Where is the thermostat located and how do you replace it thank you
Saturday, January 5th, 2008 AT 5:35 PM
MERLIN2021
  • 17,250 POSTS
Let the engine cool off, then drain it down about a gallon, there is a draicok on the bottom of the radiator, then follow the upper radiator hose to the engine, there you will find the thermostat at the end of the hose, unbolt the two bolts. Leave the hose attached to the housing. Scrape old gasket from both mating surfaces, install new thermostat, spring towards the engine. Install the gasket, snug the housing bolts! Not to tight and bring the housing down evenly. Refill the coolant and that's it!
Saturday, January 5th, 2008 AT 7:32 PM
