1995 Chevy S-10 Starting problems.
3,000 MILES • 6 CYL • 4WD • AUTOMATIC
WISKAS42015
The truck has a new 4.3L Vortec motor and ran fine for the first three months and it recently had starting problems so I replaced the starter. It still had problems so I replaced the battery as well. The alternator still works fine. The starter is turning it over but it won't start. My only guess at this point is that the fuel pump isn't working but I can hear it engage when I turn the key to on. I can't seem to find the reason it won't start.
Jun 5, 2009 at 10:20 AM
  • 75,988 POSTS
Check the fuel pressure to rule out the fuel pump if okay look for ignition spark
Jun 5, 2009 at 10:50 AM
WISKAS42015
What's the easiest way to check for ignition spark?
Jun 8, 2009 at 11:28 AM
  • 75,988 POSTS
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Jun 8, 2009 at 12:00 PM
WISKAS42015
So i tested the spark using a spark plug off of my old trans am and with the spark plug wire disconnected it started up on the second attempt at checking for spark...bad plug?
Jun 10, 2009 at 10:23 AM
