1995 Chevy S-10 Starting problem
135,000 MILES • 4 CYL • 2WD • MANUAL
SKWIRL
I replaced the alternator in my truck and a couple days later, it wont start. The starter tries to turn over, the batter is good, and that alternator seemed to be working fine. The last time I drove the vehicle, it died a few times after starting it and after a while started and I drove it home. It hasn't started since, and when I turn the key on everything works except the dash lights. They fade on and flicker then go out when I try to start the vehicle. Before the alternator was replaced, the spedometer would sometimes stop working when the heater was turned on but the vehicle didn't run long enough to see if that has stopped. What would cause this problem?
Jan 12, 2008 at 5:17 AM
MERLIN2021
  • 17,250 POSTS
Double check the battery and the cables for clean and tight, at both ends. Sounds like a partially drained battery!
Jan 12, 2008 at 5:22 AM
