HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
S-10
Engine
Starter
Replace/Remove
1995 Chevy S-10 Starter
KDUNDEE
MEMBER
1995 CHEVROLET S-10
6 CYL
2WD
MANUAL
157,000 MILES
What is the easiest way to get the starter out? Not much room and I cant find a way to get it out.
Saturday, February 27th, 2010 AT 12:10 PM
JDL
MECHANIC
Hi, I found this info, 2wd S-series pickup. I usually turn the starter in various positions, till I find a way for it to drop.
SPONSORED LINKS
Saturday, February 27th, 2010 AT 12:32 PM
Please
login
or
register
to post a reply.
Related Starter Replace/Remove Content
Starter Motor Replacement And Location?
How Do I Remove The Starter From The Chevy S10 Truck, 6 Cylinder, 2 Wheel Drive
Asked by
elpapotito
8 IMAGES
2003
CHEVROLET S-10
VIDEO
Starter Replacement
Instructional repair video
GUIDE
A starter motor is a high torque motor that utilizes a small pinion gear to contact the flywheel and a starter solenoid to initiate the electrical connection when the...
Starter Replacement?
Went Into A Business Came Back Out And Truck Would Not Start. It Just Whines. The Starter Was Replaced And It Does The Same. Shims Were...
Asked by
jaack
8 IMAGES
1993
CHEVROLET S-10
1990 Chevrolet S-10 Starter Removal
Trying To Remove Starter But Not Enough Room To Get It Out. Is There Some Secret Trick Or Do We Have To Jack Up The Engine Or What? Thanks
Asked by
Enchiladeeda
1990
CHEVROLET S-10
2000 Chevy S-10 Starter Failing Nearly Every 30-60...
This Vehicle's Starter Continually Began To Fail Almost Every 4-8 Weeks. The Starter Already Was Replaced About 4-5 Times. After The Last...
Asked by
portjeffsunoco
2000
CHEVROLET S-10
Engine Just Started To Try To Turn Backwards After...
Engine Just Started To Try To Turn Backwards After Shut Off, Long Cranktime Now Then Loud Nosie After Every Rotation, Burned Out Starter...
Asked by
DANNYMERCER
2001
CHEVROLET S-10
VIEW MORE
SPONSORED LINKS
Starter Replacement
Starter Replacement
Online car repair manuals
