1995 Chevy S-10 Stabilizer Bar Replacement Bolts, nuts and
85,000 MILES • 6 CYL • 4WD • MANUAL
JERRYTP
Please advise me if replacing the Subject Bolts, nuts and rubber bushings is a difficult task and what would be the estimated cost of the parts.
tbkmj@ptd.net
Jun 24, 2008 at 12:01 AM
DOCFIXIT
  • 18,828 POSTS
Getting the bolt off is the challenge. Soak with WD40 then loosen. If nogo you can hacksaw into.
When tightening up squezze the rubber to just slightly past the washer and no more.
Parts under $20
Good luck you can do it
Jun 24, 2008 at 12:37 AM
