1995 Chevy S-10 Stabilizer Bar Replacement Bolts, nuts and
JERRYTP
  • 1995 CHEVROLET S-10
  • 6 CYL
  • 4WD
  • MANUAL
  • 85,000 MILES
Please advise me if replacing the Subject Bolts, nuts and rubber bushings is a difficult task and what would be the estimated cost of the parts.
tbkmj@ptd. Net
Tuesday, June 24th, 2008 AT 7:01 AM
DOCFIXIT
  • 18,828 POSTS
Getting the bolt off is the challenge. Soak with WD40 then loosen. If nogo you can hacksaw into.
When tightening up squezze the rubber to just slightly past the washer and no more.
Parts under $20
Good luck you can do it
Tuesday, June 24th, 2008 AT 7:37 AM
