1995 Chevy S-10 sputtering
KDENES
  • 1995 CHEVROLET S-10
  • 4 CYL
  • MANUAL
  • 142,000 MILES
The truck sputters or hesitates after shifting gears.I noticed there is a hole in the exhaust before reaching the catalytic converter
Thursday, October 29th, 2009 AT 9:21 AM
JDL
  • 16,098 POSTS
Welcome to the forum, how long since a tune-up? Any trouble codes? My info shows your obd2.
Thursday, October 29th, 2009 AT 3:40 PM
KDENES
Had the plugs, wires, oxygen sensor and the fuel filter replaced. The coil packs were tested and a compression check on the cylinders. Both were fine. Had the timing chain checked and it was fine. The plugs were a really light color it seems to be running lean. It does run just rough. Not sure what to do?
Saturday, November 7th, 2009 AT 7:23 PM
