1995 Chevy S-10 speedometer trouble
BLUDRAGON
Electrical problem
1995 Chevy S-10 4 cyl Two Wheel Drive Manual
My shift light stays on but my speedometer doesn't work. I have replaced my speed sensor, a bad wire, the ECM and the dash cluster. None of these worked and I was wondering if it may be the VSS buffer and where its located.
May 26, 2010 at 4:37 AM
BLUELIGHTNIN6
  • 16,542 POSTS
follow steps below to pinpoint culprit .. the VSS buffer is behind rightside instrument panel..
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_2260.jpg
May 26, 2010 at 3:27 PM
BLUDRAGON
where behind the right side instrument panel exactly is it? under the ECM, behind the rightside kick panel, or behind the dash cluster, or what does it look like?
May 28, 2010 at 5:38 PM
