1995 Chevy S-10 speedometer
173,000 MILES • 6 CYL • 4WD • MANUAL
ROAD1420
ok well i have a 1995 chevy s10 pick up and the speedometer started to acted weird about a week ago and evertime i went over 45 the speed would drop to zero then slowly the max it would got before dropping to zero changed little by little it went for 45 to 40 then to 37 or so and so on till it got to zero and didn't read anything now i thought the speed sensor on the transmission might be loose cause the abs light came on too but i checked them and they are fine as far as i can tell it happened to me once before when i put a clutch in the truck and i didn't hook the sensors on the transmission back up then hooked them back up and it was all fine can you tell me if my sensors are bad or what else it might be cause i checked the fuses and all that and nothing as far as i can tell
thank you
Apr 18, 2008 at 4:39 PM
LILWILLS
  • 49 POSTS
my truck did the same thing awhile ago. its a 1995 gmc but i just changed the sensor and the problem stopped . the sensor is prolly out of range so just change it.
Apr 18, 2008 at 5:24 PM
