1995 Chevy S-10 signal lights and back brake lights
CLYDE T OTTAWAY
  • 1995 CHEVROLET S-10
  • 4 CYL
  • MANUAL
  • 135,000 MILES
I have no signal lights or back break lights I replaced the signal switch and since then I don't have either I replaced relay I have power to the switch but none going to lights.I have tried traceing wires all seem to work I need some advice on what to check i'am at a standstill. Any suggestion will be welcome.
Thursday, June 5th, 2008 AT 11:24 AM
MERLIN2021
  • 17,250 POSTS
Have you checked the stop light switch on the brake pedal arm? May need adjusting or replacement. The highmount or Cyclops is out as well right?
Thursday, June 5th, 2008 AT 1:50 PM
CLYDE T OTTAWAY
  • 16 POSTS
Yes I do have the high brake light but no rear brake light or turn signals.
Thursday, June 5th, 2008 AT 6:30 PM
CLYDE T OTTAWAY
  • 16 POSTS
Yes I do have the high mount brake light on my 95 s10.
Thursday, June 5th, 2008 AT 6:36 PM
MERLIN2021
  • 17,250 POSTS
Usually turns out to be the switch, or a pushed out pin in the plug.
Friday, June 6th, 2008 AT 2:33 AM
CLYDE T OTTAWAY
  • 16 POSTS
What and where is the push out pin.
Friday, June 6th, 2008 AT 11:35 AM
MERLIN2021
  • 17,250 POSTS
The plug at the multifunction switch. Check the pins in both halfs of the connector!
Friday, June 6th, 2008 AT 12:49 PM
CLYDE T OTTAWAY
  • 16 POSTS
Thanks you have been a big help I was at a standstill I will use this site again.
Friday, June 6th, 2008 AT 1:36 PM
MERLIN2021
  • 17,250 POSTS
Ok tell your friends!
Friday, June 6th, 2008 AT 4:16 PM
