1995 Chevy S-10 Rocker arm bolts spec
12,400 MILES • 4 CYL • 2WD • MANUAL
DOITR8
AT TDC the torque spec is 22FT.LBS on rocker arm nut's by my book on this 2.2 eng. Am I old school or should I adjust with engine running untill loose and then 1/2 trun. Do you have a recomendation, or should I use th over the counter repair book spec's.
Oct 18, 2008 at 3:37 AM
SWILLIAMS
  • 597 POSTS
The torque to spec is because those rockers are not adjustable. They bottom out on the rocker stud and your done.
Oct 18, 2008 at 6:36 AM
