1995 Chevy S-10 oil pressure
211,111 MILES • 4 CYL • 2WD • AUTOMATIC
ELMER UP
i have a question.my oil pressure is fine when i start my truck. but after i drive it the oil pressure drops.to almost nothing. then when i am idiling it goes into the orange and the check gauges light comes on .
Mar 17, 2009 at 12:38 PM
JAMES W.
  • 2,394 POSTS
Most common cause of the symptoms you describe is either worn engine bearings. With the high mileage you show, my first thought is; the motor is just plain getting tired. You can double check your dash gauge by removing the OP sending unit, and screwing a regular needle type liquid gauge in it's place but, you will find close to the same pressure reading. Hope this helps.
Mar 17, 2009 at 1:39 PM
