1995 Chevy S-10 no fuel
NASFN3
  • 1995 CHEVROLET S-10
  • 6 CYL
  • 4WD
  • 225,000 MILES
Ok i got the diagram but i now have a few ? about it the orange wire is that my power and the gray is my feed will the fues be an inline for the ecu / fuel pump and will the diagram work with a z code motor also
http://www.2carpros.com/forum/automotive_pictures/478480_170934_s10_wiring_1_1.jpg
Monday, February 8th, 2010 AT 11:35 AM
VIN Z, The fuel pump fuse is the ECM/BATT fuse no.9 20amp which has the orange wire, and the gray wire is your power input to the fuel pump which comes from the fuel pump relay for 2secs, once the engine fires up the fuel pump sending unit powers it all the time thru the gray wire-
https://www.2carpros.com/forum/automotive_pictures/12900_oil_sending_unit_and_fuel_pump_circuit_101.gif
Monday, February 8th, 2010 AT 1:26 PM
