1995 Chevy S-10 No Clutch pedal travel
160,000 MILES • 6 CYL • 4WD • MANUAL
JOHN1948
I removed my clutch slave cylinder in order to replace my faulty starter. When I put slave cylinder back on I cant get the clutch pedal to move any travel at all. Clutch does not activate.
I have since read that I should have unhooked push rod to master cylinder before removing slave cylinder.
What do I do to get clutch working again? There was no clutch problem before I removed slave cylinder.
Oct 20, 2008 at 3:31 AM
SWILLIAMS
  • 597 POSTS
Bleed the system to remove any air.
Oct 20, 2008 at 7:03 AM
