It's the same truck. The only difference is if it's a 2.8 or a 4.3L engnine, There is the universal mount trans case and ones 2.8 seperately. If you are going from a 2.8 to a 4.3 you will have to change torque converters for balance and you may need to change the oil pump depending on the size of the oil pump.
SPONSORED LINKS
Monday, March 29th, 2010 AT 5:58 PM
