1995 Chevy S-10 Horn-cig lighter
17,800 MILES • 6 CYL • 2WD • AUTOMATIC
MR_JAIME
I checked The fuse. It was blown. I replaced it and I still don't get power to my horn or lighter also when I open the door the light don't turn on.
Nov 10, 2009 at 1:32 AM
JDL
  • 16,098 POSTS
welcome to the forum, Did you use a testlite on the horn fuse circuit, should be hot all the time. The fuse probably has a bare spot on top of each leg, so you can check voltage without pulling the fuse, or you can pull the fuse and check for voltage, either way. There may be a problem with fusible link at junction block?
Nov 10, 2009 at 2:06 AM
