1995 Chevy S-10 Emergency light switch
LANDON
Electrical problem
1995 Chevy S-10
I broke the emergency light swith off, witch is back be hind the stirring wheel while removing the dash to put a sterio system in. What do i need to do about the light switch because the emergency lights will not turn off now?
Mar 12, 2010 at 1:02 PM
BLUELIGHTNIN6
  • 16,542 POSTS
temporarily you could remove the fuse for the flashers but for a permanent fix you will have to replace the hazard flasher switch itself.
Mar 12, 2010 at 1:09 PM
