1995 Chevy S-10 electrical problem
MARVIN D
1995 Chevy S-10 Two Wheel Drive Automatic 145000 miles
vehicle starts fine when engine is cold, but there appears to be a power drain after engine is at operating temp, making restart difficult (tho' voltmeter check of battery shows more than adequate voltage)
Jul 26, 2008 at 5:58 AM
JDL
  • 16,098 POSTS
What is the reading across the battery posts, with everything turned off? What is the reading, with the engine running? The reading should be higher with the engine running. Are you saying it is a slow crank on restart? I think some of the national brand autostores will check batteries free of charge. Are the cables clean on both ends?
Jul 27, 2008 at 8:41 AM
