1995 Chevy S-10 Distributor replacement
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
GOODOLBOY
This engine does not have powertrain control module. I had to change the distributor. Put timing in top dead center #1 at compression.
Question, does the rotor line up with the #1 contact
on the distributor cap or the arrow that is on the distributor shaft or where?
This truck has a 4.3 Vortec "W" engine with CPI with ECM 3 pin plug on the control module inside the distributor. I am having trouble getting it to fire plus
if I short the coil wire to ground the spark is light and has an orange color.
Jun 17, 2010 at 3:15 PM
  • 75,988 POSTS
Test the ignition coil primary and secondary windings resistances
If its on TDC on compression stroke and crank pulley markings at 0/TDC the rotor should be pointing to no.1 tower this is where the firing order starts 165432
Jun 17, 2010 at 3:54 PM
