Engine Mechanical problem
1995 Chevy S-10 4 cyl
I have spark in the plugs, as well as fuel thru the fuel pressure regulator, but it still won't start. I was told there is a part in the distributor that may be a problem, but have no idea what that would be. Can you advise? It does sound like timing is off. Thank you for any and all help you can give.
Mar 30, 2009 at 3:51 AM
