1995 Chevy S-10 Distributor
ANTHONY JAUREQUI
  • 1995 CHEVROLET S-10
Engine Mechanical problem
1995 Chevy S-10 4 cyl
I have spark in the plugs, as well as fuel thru the fuel pressure regulator, but it still won't start. I was told there is a part in the distributor that may be a problem, but have no idea what that would be. Can you advise? It does sound like timing is off. Thank you for any and all help you can give.
Monday, March 30th, 2009 AT 10:51 AM
JDL
  • 16,098 POSTS
Hello, the s10 four cylinder pickup shows dis ignition.
The s10 blazer shows distribution ignition, but that is a 6 cylinder.
If you have the coil driver module that is separate from the distributor, if the coil driver module, has a purple wire with white tracer, that sends the rpm signal to the computer, without that signal, the computer won't pulse the injector/s. I haven't looked at your injector, do you have that spider fuel system?
Monday, March 30th, 2009 AT 11:28 AM
ILOVETHE800
  • 10 POSTS
If you have spark and good fuel pressure then it is more than likely the coil driver(ignition module). You might want to spray some starting fluid into the manifold just to check and see if it is fuel or spark. I have seen a few s10s that have had spark and fuel pressure and still would not run. Usually the problem lies with the ignition module. You can check to see if the injectors are being pulsed if you have access to a noid light set.
Tuesday, March 31st, 2009 AT 7:16 PM
ILOVETHE800
  • 10 POSTS
Also if you have the cpi(vortec/spider) injected v6 then I doubt it is out of time. It would be odd for this engine to jump time unless something were wrong with a timing chain(unlikely) or you removed the distributor. If you have the throttle body injected v6 then yes you definately want to consider checking the timing
Tuesday, March 31st, 2009 AT 7:20 PM
