1995 Chevy S-10 Dash Removal
12,300 MILES • 6 CYL • 2WD • AUTOMATIC
TATERTOT5220
Removed dash to replace heater core. Now turn signals do not work, air bag light is on, and shifter indicator not working. Car starts and runs fine though.
Mar 21, 2010 at 3:41 AM
KHLOW2008
  • 41,812 POSTS
Hi tatertot5220,
Thank you for the donation.
If the hazard lights are not working as well, check the hazard switch wire connectors.
If the steering wheel was removed, you could have damaged the clock spring reel under the wheel esulting the air bag lights indicating
As to the gear shift indicator lights, recheck the wireharness connectors.
Mar 21, 2010 at 5:02 AM
TATERTOT5220
Steering wheel was not removed, checked all the connectors. Could the DERM be the problem, is the SIR interconnected with all this?
Mar 21, 2010 at 5:21 AM
KHLOW2008
  • 41,812 POSTS
The turn signals and park position indicators are not related to the DERM.
Sorry I do not understand what is meant by SIR.
The ABS indicator light is related to the DERM and for diagnostics, appropriate equipments would be required.
Mar 21, 2010 at 8:00 AM
TATERTOT5220
Supplemental Inflatable Restraint (Air Bag system)
Could there be a malfunction code that needs to be cleared?
Mar 21, 2010 at 8:04 AM
KHLOW2008
  • 41,812 POSTS
Sorry, I normally refer the restraint system as SRS.
Yes, you would need a scanner to erase the trouble code.
Mar 21, 2010 at 8:07 AM
