1995 Chevy S-10 Code Reading
76,500 MILES • 6 CYL • 4WD • AUTOMATIC
MSTECK08
Can I ground a terminal on my data link connector to read the flashes for a fault code? And if so, what number terminal? I have an engine VIN Z.
Jun 16, 2008 at 1:11 PM
BMRFIXIT
  • 19,053 POSTS
some 1995 came in with the OBD connector
and if so u need a code reader
but if you have the ALDL connector you can ground the two terminals to the codes by flashing check engine light
Jun 16, 2008 at 1:48 PM
