1995 Chevy S-10 brakes not working correctly
115,000 MILES • 6 CYL • 2WD • MANUAL
DANDI
all of a sudden the brakes on my truck starting acting like they are manual brakes instead of power brakes. There is a noise that they make when I press on them that sounds like air filtering out of something. Also whe I press on the brake my engine runs faster. I do not have good stopping ability as well
thanks for your help
Aug 11, 2009 at 4:32 AM
  • 75,988 POSTS
Could be a vacuum leak on the brake hose and brake booster
To check the brake booster, pump the brake pedal with the engine off until you've bled off all the vacuum from the unit. Then hold the pedal down and start the engine. You should feel the pedal depress slightly as engine vacuum enters the booster and pulls on the diaphragm. No change? Then check the vacuum hose connection and engine vacuum. If okay, the problem is in the booster and the booster needs to be replaced.
Aug 27, 2020 at 11:31 AM
