1995 Chevy S-10 blower motor
254,000 MILES • 6 CYL • 2WD • MANUAL
DIRTY 1
on 1995 chevy S-10 when I turn my a/c on high the fan cuts out, I've replaced the blower motor switch, the a/c resistor, and checked fuses and relay and they are good. still having the same problem. is there anything that i'm over looking.
Jun 12, 2010 at 12:03 PM
  • 75,988 POSTS
Recheck and test the blower motor relay and test the ground point at G-114 rear of left cylinder head
Jun 13, 2010 at 12:11 AM
TONY.NIEMANN
  • 5 POSTS
You need to read my post at:
https://www.2carpros.com/forum/1995-chevy-s-10-blower-motor-vt485585.html
You have a bad relay on the firewall. It is the one of three mounted on the firewall and has a purple, orange, blue, red, and black wire going to it. Take the plug off and visually inspect the contacts. The red one should be bad. I will sell you a good relay for the price I paid - $15, or you can go to the junkyard and buy the assembly. I had to replace my plug also because the wire and pin going to the red connector was burned open as a result of the bad relay.
tony.niemann@elkcreek.net
Jul 31, 2010 at 3:38 AM
