1995 Chevy S-10 ABS PUMP-2 OR THREE PRONG
DDK56
Brakes problem
1995 Chevy S-10 6 cyl Four Wheel Drive Automatic
Which plug, do you go by to tell if it is a two prong pump or three prong pum ? there is three sets of wires. I need to replace the abs pump, but i need to know if it is a two or three prong pump.
Oct 8, 2010 at 2:21 AM
HMAC300
  • 48,601 POSTS
the parts store should be able to tell which you have by finding out wheteher you have a VCM or a PCM. A VCM is under the hood by the right front fender. It's pretty good sized and it has like fins on top by the accumalator.
Oct 8, 2010 at 12:50 PM
