Engine Mechanical problem
1995 Chevy S-10 4 cyl Two Wheel Drive Automatic
HAVE NO SPARK
Mar 4, 2010 at 2:01 AM
JDL
✓Experienced Mechanic
Hi, I'd have to check voltage and ground to the ignition module. Pink wire is voltage, goes hot when you turn on the key. Black wire with white tracer is ground. If that checks out, Possible issue with crank sensor or ignition module?
