1995 Chevy S-10
JAYROCK0409
Air Conditioning problem
1995 Chevy S-10 4 cyl Two Wheel Drive Manual
the defrost is the only function that will work on the heater/ac control no matter what function you put the dial on(max air,normal air,vent etc) would replacing the heating/ac control fix the problem?
Aug 6, 2009 at 12:43 PM
CLECO
Just fixed the same problem on my 95 S10 Blazer; It was a vacuum leak. The climate control is vacuum actuated. I had a leak in the small vacuum line that attaches at the back of the intake manifold (next to distributor). My Blazer has the 4.3 Vortec V6 [Vin W with VCM-A computer]. Hope this helps.
Aug 17, 2009 at 1:23 PM
