1994 Chevy S-10 6 cyl Four Wheel Drive Automatic
My s-10 blazer was having a hard time starting so I changed the plugs, wires, cap and rotor and now it won't start at all. I was told to try the fuel pressure regulator because when it was starting I could smell gas really strong. If I hold the gas pedal down I can get it to run but only barely increase the rpms as I hold down the pedal. As soon as I let of the pedal it dies. The comp gave me a TPS / ECM code and we changed the tps. The ECM is costly so I don't want to just change it is there something else I can try?
Monday, April 21st, 2008 AT 9:09 PM
