1994 Chevy S-10 turn signals
165,000 MILES • 4 CYL • 4WD • AUTOMATIC
MARIARR1
replaced all turn signal bulbs front back sides rear, still not working, replaced fuse, where is the other fuse box, i know there is one by the driver side door got that but there is another where is it located???
thank-you
Sep 4, 2010 at 10:56 AM
BLUELIGHTNIN6
  • 16,542 POSTS
'94 s10 only has 1 fuse box, turn signal fuse is #16 should be labeled Turn-B/U 15 amp fuse.. if fuse is good than turn signal flasher is probably at fault.
Sep 5, 2010 at 9:54 AM
CHEVY LOVER
there is 2 under the hood up close an to the top of firewall u can hear them click when your signal is on if its working.
Jan 18, 2013 at 7:17 AM
