1994 Chevy S-10 Turn signal and hazard light fuse repeatedl
TAPIAD
Electrical problem
1994 Chevy S-10 6 cyl Two Wheel Drive Automatic
Just had this problem start last night. My turn signals weren't working and I replaced the fuse which got them working. That burnt out immediately. I thought it may have been a bad fuse, replaced it again and it burned out very quickly once more. I also noticed this morning that my hazard lights aren't working either. I replaced that fuse and it burned out after one single blink.
One thing I noticed when I replaced the turn signal was that the speedometer jumped slightly when the turn signal fuse blew.
Any help and suggestions?
Jul 20, 2010 at 8:12 AM
DOCFIXIT
  • 18,828 POSTS
Hi Maybe a short in a bulb check turn signal bulbs for a broken filiment that could be touching bulb ground . If all good problem could be in turn signal switch.
Hope this helps
Thanks for donate
Jul 20, 2010 at 8:21 AM
