1994 Chevy S-10 Tailgate Cables
211,000 MILES • 6 CYL • 2WD • AUTOMATIC
MIKRIS
My tailgate support cables snapped the other day and the replacement cables did not come with any mounting hardware. The original cables are mounted to the tailgate with a large rivet which I have to drill out to remove. Is there an alternative to the rivet for attaching the cable to the tailgate and if so where would I get it?
Aug 2, 2008 at 12:54 AM
NEWTONS10
Very simple. I just did this today on my '99. Go to a Chevy dealer and get a recall kit: Part #15939908. It comes with two new cables and two new connecting bolts. (These are for a 2000 Chevy but it should fit yours okay.)
Use a 3/8" drill bit and drill out the existing rivets. Then use the 3/8" bit to enlarge the holes in the brackets where the rivets had been. Now remove the screws holding the mounting brackets into the tailgate. With the brackets loose, you can install the new cables with the new connecting bolts using wrenches. Then just put everything back together and you're set.
It's actually a nice install and if the cables break again, you can easily replace them with wrenches... no stupid rivets!
Good luck.
Aug 5, 2008 at 2:22 PM
MIKRIS
Thanks Newton for the reply. That's pretty much what I did although it was at Part Source and not my Chevy dealer.
Aug 5, 2008 at 2:26 PM
