1994 Chevy S-10 Severe grinding!!
127,000 MILES • 4 CYL • 2WD • MANUAL
TM_STEVENSON
Hello, my question is, I have an 94 Chevy S10 and when i put it into either first or reverse it makes a very distinct grinding sound before going in to gear, whta do you think the problem could be? and how could it be fixed? Thanks!
Jan 26, 2008 at 11:49 AM
  • 75,988 POSTS
Check the clutch master cylinder-if low fill it and then bleed the clutch slave
Then adjust the free play and pedal height-all these don't work-its time for a new clutch assembly.
Jan 26, 2008 at 6:09 PM
