1994 Chevy S-10 right directional signal
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
SPARELANES
The left turn signal works, the Hazard lights all work correctly. However, when turning on the Right turn signal (directional), the light blinks 1-2 times, then the fuse blows.
I have changed the flasher unit, to no avail.
Since the Hazards work, is the turn signal switch the most likely culprit?
Feb 27, 2010 at 7:14 AM
POORMNSDVD
  • 9 POSTS
not an easy job but start at the light socket trace the wire along the frame and find where it rubbed through
whats happening is its shorting out every time it draws juice
Feb 27, 2010 at 7:24 AM
SPARELANES
[quote:db30f366a3="poormnsdvd"]not an easy job but start at the light socket trace the wire along the frame and find where it rubbed through
whats happening is its shorting out every time it draws juice[/quote:db30f366a3]
In your opinion, is it better to start at the front or the rear of the vehicle?
Feb 27, 2010 at 7:46 AM
POORMNSDVD
  • 9 POSTS
its one of two things
bad signal relay which you said you replaced
or the switch itself
Mar 2, 2010 at 7:16 AM
POORMNSDVD
  • 9 POSTS
and you want donations
Mar 2, 2010 at 7:17 AM
