1994 Chevy S-10 Overheating,water leaking
30,000 MILES • 6 CYL • 2WD • AUTOMATIC
JACOB_SYKES28320
My s10 leaks the water out of the radiator as fast as i put it in. It is leakin where the house goes into the engine. I was told it is propably the themostat housing. It is not leaking from the hose but inside where the hose runs.I just got the truck so i'm not sure. I was wondering if the thermostat housing was the reason?
Jan 24, 2008 at 9:35 AM
  • 75,988 POSTS
Thermostat is stuck closed not permitting coolant to flow thru out the engine
Jan 24, 2008 at 12:45 PM
