1994 Chevy S-10 MAP sensor
165,000 MILES • 6 CYL • 2WD • AUTOMATIC
JMICHAEL8888
  • 45 POSTS
my truck is a CMFI fuel system. i got this truck from my brother and it has always run poorly (low power). my question is would a map sensor vlotage reading of 3.8v at idle be causing my computer to think it has low vacuum?or be causing it to run weak. a vacuum test shows a steady 18.5psi acceleration test normal.
Dec 3, 2008 at 1:07 PM
RACEFAN966
  • 5,029 POSTS
Ok the voltage for map sensor should be 1 to 2 volts at idle and at wide open throttle it should be 4 to 4.8 volts. So if it is showing 3.8 volts at idle then it would think it is at wide open throttle and give more fuel which would give you poor mileage and poor performance.
Dec 3, 2008 at 1:47 PM
