1986 s10 engine idles rough after about 30 seconds of runtime. Engine light flashes sometimes while driving. When I check for engine codes all I get is 12. Why doesn't it give a code for the problem? Also I tried unplugging the map, tps an 02 sensors an driving it an the light didn't do any different an no codes were stored. It has new airfilter. Plugs, wires, distributorcap, rotor button, egr valve, fuelpump fuel filter, airtemp sensor, an map sensor
SPONSORED LINKS
Monday, September 28th, 2009 AT 5:07 AM
