1994 Chevy S-10 manual window crank
126,500 MILES • 6 CYL • 2WD • AUTOMATIC
SAMMON3
my window handle broke and i bought a new one. what is the easiest way to take it off. are there any special tools to make it easy? are there any tricks or tips to make it easy?
Thanks ,
Kevin sammon
Jul 17, 2008 at 4:23 PM
SWILLIAMS
  • 597 POSTS
There is a special tool to remove the clip that retains the handle. BUT if your only doing it once you can use a stiff piece of wire to reach in and push the clip off. Push in on the trim panel around the handle and you will see the clip.
Jul 19, 2008 at 6:36 AM
