1994 Chevy S-10 idle arm
1994 CHEVROLET S-10
151,000 MILES • 6 CYL • 2WD • MANUAL
BOB STRASEN
  • 8 POSTS
how hard is it to replace a idle arm?
Dec 15, 2007 at 6:13 AM
MERLIN2021
  • 17,250 POSTS
Not hard at all...You will need a tie rod seperator, remove the nut on the pivot, remove the two thru frame bolts, and take it off. Some GM idler arms can be tightened, big nut on the bottom...
Dec 15, 2007 at 6:27 AM
