1994 Chevy S-10 fuel pump
MASTERBATES_56
  • 1994 CHEVROLET S-10
  • 6 CYL
  • 150,000 MILES
How do you change a fuel pump on a 1994 chevy s10 pickup?
Saturday, December 27th, 2008 AT 7:12 PM
JMICHAEL8888
  • 45 POSTS
The fuel pump is in the tank so you have to drop the tank to change it. I recommend spending the $20 for a manual at a local parts store or order one from this site.
But it goes something like this(drain tank)
1. Relieve fuel pressure
2. Remove negative cable (for safety)
3. Remove fuel tank shield
4. Disconnect all fuel lines in and out and vapor
5. Remove straps holding tank (jack under)
6. Lower tank with jack a little and disconnect wires from pump
7. Rotate pump and unlock from locking tabs
8. Lift from tank
Saturday, December 27th, 2008 AT 9:57 PM
