1994 Chevy S-10 Fluctuating Oil Pressure
184,000 MILES • 4 CYL • 2WD • MANUAL
JDOUG01
I recently purchased a 1994 S10 with 184000 miles on it. I noticed that when I start the truck the oil pressure is a little high. Its sitting around 60. As I drive longer the oil pressure begins to drop when I am not giving gas to the engine. When I do give it gas the pressure jumps back up again. Is there any preventative maintenace that I could do the help keep the pressure at a normal level. Any other suggestions would be greatly appreciated. Thank you.
Mar 16, 2010 at 8:11 AM
  • 75,988 POSTS
Check the oil pressure with a mechanical gauge,if normal replace the oil pressure switch.If abnormal could mean oil pump and/or engine bearing.
Mar 16, 2010 at 8:44 AM
