1994 Chevy S-10 Engine wants to stall
SAPSAP7162
  • 1994 CHEVROLET S-10
  • 4 CYL
  • 186,000 MILES
I have a 1994 Chev s-10 that starts a nd idles fine. When I give it gas it stutters and misses. If I put it in gear, hold the brake, and mash it to the floor than it will bog down and spit a sputter with a small backfire sometimes. The check engine light is not on. I was thinking maybe a tune up but there it has a coil pack. Please help. I love my old truck.
Thursday, June 3rd, 2010 AT 8:44 AM
TOOOMANYTOYS
  • 513 POSTS
I would start with checking the fuel pressure and also taking a few sample.
Thursday, June 3rd, 2010 AT 8:52 AM
SAPSAP7162
I'm going to just do a complete tune up. Plugs, wires, all filters. Can't gp wrong with that. I just hope it's not one of those sensors. Without a code it's like throwing money into a fire
Thursday, June 3rd, 2010 AT 8:55 AM
TOOOMANYTOYS
  • 513 POSTS
If the plugs and wires are original they need to be replaced anyway. Its not likely to be a sensor because you have no codes.
Thursday, June 3rd, 2010 AT 4:01 PM
SAPSAP7162
Thanks for all the help. Did a tune up(plugs wires filters including fuel) still same results. Changed TPS and it fixed it. Think the light may be burned out or something but it runs like a champ now. Thanks fo rall the imput
Friday, June 4th, 2010 AT 12:10 PM
TOOOMANYTOYS
  • 513 POSTS
When you first turn the ignition on the cluster goes into bulb check. See if the service engine soon light comes on then. If not the bulb is probably out.
Sunday, June 6th, 2010 AT 4:47 PM
