1994 Chevy S-10 Chevy S-10 Starts up and dies
PROTEAN85
  • 1994 CHEVROLET S-10
  • 4 CYL
  • MANUAL
  • 18,000 MILES
Hi, I have a chevy s-10 180k miles 2.2 cyl 2wd, had an issue with my starter not too long ago, replaced it about 3 weeks ago. Had to drive my truck 180 miles back from parents house to my apartment. Went to work for 2 days, on the second day, the engine started sputtering and dies, whenever I try to give it gas, it struggles to move. Just replaced my O2 sensor, hoping that was the issue. Please don't tell me its my fuel pump.
Tuesday, September 8th, 2009 AT 8:21 AM
JOERIN42
  • 8 POSTS
I had same issue for couple of weeks. I thought it was the timing chain. Sometimes it would start, other's it would but run sloppy. I changed my timing chain (took a few days. 4.3 6 cyl is not like my old 70's Oldsmobile's). It ran fair for a week and then would not start. It WAS the fuel pump/sending unit. If you ever ran out of gas, that would cause the fuel pump inside the tank to 'go to bed'. Try this. With all accesories shut off, and no other backround noise, open driver's door, turn the key as to start the engine. Try to listen for the fuel pump to function/run. If you hear nothing, then the pump is not functioning. Be aware: when replacing the pump, normaly the sending unit and lines on an older model will need raplacing too. I live in Pa, long nasty Winter's and alot of salt. My tank was also shot so spent over $600 for entire fuel tank, pump assembly.
Sunday, September 13th, 2009 AT 9:43 PM
