1994 Chevy S-10 engine timing
CHRISTINEBOSSDR
Engine Performance problem
1994 Chevy S-10 6 cyl Two Wheel Drive Manual
When timing engine is there a defuser or wire to disconnect to stop timing advance?
Jul 13, 2010 at 8:34 AM
  • 75,988 POSTS
You need to disconnect the EST wire tan and black wire-see below info
https://images.2carpros.com/forum/automotive_pictures/12900_est_4.jpg
Jul 13, 2010 at 8:50 AM
MERLIN2021
  • 17,250 POSTS
V6 IGNITION TIMING 1. Set parking brake, block drive wheels and place transmission in Neutral or Park. Warm engine to normal operating temperature. Turn A/C off (if equipped). Ensure Malfunction Indicator Light (MIL) is off. 2. Disconnect Tan/Black Electronic Spark Timing (EST) by-pass connector wire. DO NOT disconnect 4-wire connector at distributor. 3. On models where engine computer is located underhood, on right fenderwell, by-pass connector which is a single Tan/Black wire, breaks out of wiring harness near engine computer harness connectors. 4. On models where engine computer is located in passenger compartment under right side of instrument panel, by-pass connector which is a single Tan/Black wire and breaks out of wiring harness where heater box and carpet meet on passenger side floor. Pull back carpet to expose single Tan/Black wire and connector on outside of control module harness. 5. On all models, connect timing light to No. 1 spark plug wire. Check timing and adjust if necessary. See V6 IGNITION TIMING table. Reconnect EST by-pass connector, and clear ECM trouble code. NOTE: The location of the EST by-pass connector has been updated per General Motors Service Manual Update number 41-65-41, dated January 4, 1995.
Timing is 0 degrees at idle, both auto and manual trans. Soory Razz! But this IS clearer!
Jul 13, 2010 at 8:53 AM
WILLARD TAYLOR
It is well hidden tan wire with black stripe taped to harness coming out of passenger side kick panel.has took me 14 years to find
Jan 1, 2020 at 1:46 AM
TOUGHDIVER
  • 226 POSTS
You could also jumper A TO B terminal at the 16 pin data link connector under drivers dash it will disable timing advance also. Hope this was helpful.
Thank you
Joe T.
Jan 2, 2020 at 8:55 AM
