1994 Chevy S-10 engine knock
1994 CHEVROLET S-10
126,000 MILES • 6 CYL • 4WD • MANUAL
MILKMAN0180
I believe that one of the main bearing has come loose causing the engine to have a loud knocking sound coming from the lower rear of the engine. I was wondering would it be easier to just drop oil pan and replace bearings or would it be better to remove whole engine? or if there were any other things i should check first, engine still runs fine plenty of power.
May 25, 2010 at 10:22 AM
You can just go below and drop the pan to get at it
May 26, 2010 at 1:17 AM
