1994 Chevy S-10 crank censor
69,000 MILES • 4 CYL • 2WD • MANUAL
ETHANHU
I bought a 1996 chevy s-10 motorand all the plug ins worked but the crank censor. I own a 1994 s-10 chevy. Both have the same motor. So i believe that the coil pack isnt firing because of the censor. It would be greatly appreciated if you could help me considering im new at this.
Jan 5, 2008 at 7:53 AM
BMRFIXIT
  • 19,053 POSTS
[quote:1dc7c3f0d5="ethanhu"]Electrical problem
1994 Chevy S-10 4 cyl Two Wheel Drive Manual 69000 miles
I bought a 1996 chevy s-10 motorand all the plug ins worked but the crank censor. I own a 1994 s-10 chevy. Both have the same motor. So i believe that the coil pack isnt firing because of the censor. It would be greatly appreciated if you could help me considering im new at this.[/quote:1dc7c3f0d5]
It is all the same but one sensor it want plug .
why don’t you replace that sensor with the one from the old engine you know it plugs OK
ECM depend on sensors to determine where is each cylinder position in relation to the cam shaft
with out it no fire
good luck let me know
Jan 6, 2008 at 12:10 AM
